Posted: 2020-07-05 08:39 PM . Last Modified: 2024-04-03 01:08 AM
When I selected a room in the DCO web client, the power summary display on the right side column showed both the estimated power and measured peak power. Would like to understand where is this measured peak power come from ? Is it from the script for the room in the EE Configuration under planning in DCO?
(CID:147195156)
Hi Jimmy,
Those measured power are coming from the associated devices (in the room) and completely unrelated to EE scripts.
Kind regards
(CID:147195907)
Posted: 2020-07-05 08:39 PM . Last Modified: 2023-10-22 02:23 AM
