How do i set up daily humidity/temp reports
  • EcoStruxure IT forum
  • How do i set up daily humidity/temp reports
124
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-05 08:26 PM . Last Modified: ‎2024-04-03 01:13 AM
665
How do i set up daily humidity/temp reports to be emailed to a group?
(CID:146669911)
Replies 4
665
Hello Mr Muro,
Scheduling a Report to Export Data
1) Open the Data Center Expert Client and navigate into the Reports perspective.
2) Create a new report or run a saved report and select Edit Report Criteria icon in the upper-right of the report.
3) You can schedule the report to run on a regular basis in the left pane under Name and Schedule Data Export.
4) Select the checkbox for Enable Export.
5) For the Export name option, select Add Export...
6) Select a type for the export and select Next.
7) Fill in the necessary details for the export and then select test-export and a test file should be sent to the destination system.  Select Finish.
😎 Change the Delimiter and Locale if necessary and then choose the Scheduling for the report to be automatically exported.
9) Select the Report Interval, which by default will contain all available data.
10) Select OK and the report will be generated and scheduled to run on a basis that was defined.
NOTE: Data Center Expert will only export data as a text file using the delimiter that was defined in the Name and Schedule Data Export settings.
I also written a tip on how to generate reports in DCE which may be useful for you. You can access it here.
There is also a K-base available: https://www.apc.com/om/en/faqs/FA301697/
I hope this helps.
Bala
(CID:146669919)
I'm able to generate the report.. However the zip file does not open as a graph.
They need to see a graph
(CID:146670004)
Scheduled reports only include raw data, no graphs.  There is no current way to have graphs in scheduled reports.
(CID:146670009)
Posted: ‎2020-07-05 08:26 PM . Last Modified: ‎2023-10-22 02:22 AM
