How do I set language in struxureware portal?
  • EcoStruxure IT forum
  • How do I set language in struxureware portal?
125
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-03 05:56 AM . Last Modified: ‎2024-04-08 11:11 PM
806
Dear Experts,
How do I set language in struxureware portal? Or does it support Simplified Chinese?
Ziqiang
(CID:108825011)
  • Portal
Posted: ‎2020-07-03 05:57 AM . Last Modified: ‎2024-04-08 11:11 PM
Hi Ziqiang ( ziqiang wu )
It seems liferay itself supports display settings for different languages via:
 Control Panel --> My Account --> Display Settings
changing the language here will be instant, but that may not change the language of everything (specially the portlets):
hope this helps,
Kind regards
(CID:108825477)
Hi Ziqiang,
As far as I know StruxureWare Portal is not localized, so there is no option to select/change its language. But I will recheck and get back to you soon, thanks.
Kind regards
(CID:108825013)
hope this helps,
Kind regards
(CID:108825477)
Posted: ‎2020-07-03 05:57 AM . Last Modified: ‎2023-10-31 11:02 PM
