How do I register server in HP Moonshot 1500 Chassis?
  • EcoStruxure IT forum
  • How do I register server in HP Moonshot 1500 Chassis?
124
110
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-04 06:10 PM . Last Modified: ‎2024-04-04 11:40 PM
854
How do I register server in HP Moonshot 1500 Chassis, i have 45 server in each Moonshot Chassis?
(CID:131965990)
  • Data Center Operation
Hi Carsten,
I don't think that is directly possible to model, however I was wondering perhaps using the device custom properties could be useful:
The tool-tip in rack view would also display these properties:
as well as in web-client:
PS. Your 'HP Moonshot 1500 Chassis' doesn't seem to be included in Genome Library, so for the time being you might want to customize one (by taking & customizing a similar device from Genome Library). You might also want to post a request here: http://sxwhelpcenter.ecostruxureit.com/devices , so it can be added in a future Genome update.
Hope this helps,
Kind regards
(CID:131967241)
Hi Carsten,
Hope this helps,
Kind regards
(CID:131967241)
Hi
 Thejaswi have anwser me:
Hi, I have processed the HPE Proliant M710X and the HPE moonshot 1500 both in the system. I was unable to find the weight of the HPE Proliant M710X. Hence I have taken the nearest weight value of a similar unit as 20 lbs. You can start using the genomes after our next genome file release, which will be done on last week of every month. If you have any other questions, please let me know. I will be glad to help you. Regards Thejaswi
  • Thejaswi Manjunatha
BR
Carsten
(CID:132659269)
Posted: ‎2020-07-04 06:11 PM . Last Modified: ‎2023-10-22 02:21 AM
