How do I generate a quantity of used Rack U report?
  • How do I generate a quantity of used Rack U report?
129
72
Posted: ‎2020-07-04 03:20 PM . Last Modified: ‎2024-04-05 12:38 AM
1072
I am trying to generate a simple report of how many rack U's are used on 1 floor in our DC Operations software.
(CID:129407023)
  • Data Center Operation
1072
Hi Jason
Assuming your floor DC is in a "Location" by itself, use "Analytics - Reports - Rack U-space" reports like the 1st screen shot below.  Or hover your mouse of the DC summary graphic 2nd screen shot
If you've modelled the multiple floors in one DCO room, use the equipment browser to do your own calculation.  Select required columns and filter rows (you can save the EB setup) and then "Export Table"
Or you can write your own report for something "custom" (requires Insight) or have it done for you
Hope that helps, let me know if you need more
Cheers
(CID:129407110)
Replies 5
1073
Hi Jason
Cheers
(CID:129407110)
Well how do you get the extra reports??? I only show the following I am on version 8.1:
(CID:129407116)
Perhaps you only have licenses only for the base DCO product?  And the Rack u-space report is part of the DCO:Capacity product?  I can't be sure on this.
You can check using a web browser and  http:///clients/handleLicense/?action=listDetailed
In any event, i believe you can still use the EB method.
Otherwise purchase DCO:Capacity licenses, same number as DCO (many many great features) or purchase the DCO:Insight license and write your report or pay to have the report written.
Let me know if you need more help
Ed
(CID:129407123)
Awesome, thank you, think that answers my question! I don't believe we installed the capacity portion since the 8.1 upgrade we did have it in the 7.5 version! I can get what I need through the EB. Thanks a lot for your time!
(CID:129407131)
Posted: ‎2020-07-04 03:20 PM . Last Modified: ‎2023-10-22 02:20 AM
