Posted: 2020-07-04 12:42 AM . Last Modified: 2024-04-05 04:29 AM
How can I delete my existing DCE database and recreate a new one?
(CID:126164572)
Hi Mario,
If you wish to start all over again, you'll want to simply restore the server if it is hardware. If it is a VM, you'd want to create a new VM. Keep in mind that you'd need to create it with the same mac address or you'll have to contact tech support to reset the passcodes. License keys are tied to the server mac address. There is no option to wipe out the database. You can purge data but that is not the entire database and some things (configuration, device, etc) will remain.
Steve
(CID:126164582)
Hi Mario,
Steve
(CID:126164582)
Posted: 2020-07-04 12:42 AM . Last Modified: 2023-10-22 02:18 AM
