How can I change temperature from Fahrenheit to Celsius in reporting ?
  • How can I change temperature from Fahrenheit to Celsius in reporting ?
129
72
Posted: ‎2020-07-03 10:18 AM . Last Modified: ‎2024-04-08 02:36 AM
2626
StruxureWare Data Center Expert 7.4.1, Main information about temperature in Monitoring section or in Dashboard gadgets are in Celsuis, but when I try to generate some report regarding temperature, all information is in Fahrenheit .
(CID:110020196)
  • DCIM Support
2622
 Hi Ara,
kindly follow the below steps to change the temperature from Fahrenheit to Celsius.
    1) Go to the file and click on Client Preferences.
2) change the setting from Local OS to English Metric and restart the client.
BR,
Rana Ajmal
(CID:110020914)
2623
 Hi Ara,
BR,
Rana Ajmal
(CID:110020914)
Hi Rana,
Thank you so much, your answer was very helpful!!!
I have spend so many time to find the setting, but unfortunately.
It works.
(CID:110020949)
Posted: ‎2020-07-03 10:19 AM . Last Modified: ‎2023-10-22 02:18 AM
