Hikvision Access control and CCTV integration with DCE
  • EcoStruxure IT forum
  • Hikvision Access control and CCTV integration with DCE
124
65
Back to EcoStruxure IT forum
shoaibmaqsood52
Lieutenant JG shoaibmaqsood52
Lieutenant JG
Posted: ‎2023-12-31 09:19 PM
912
We have installed the DCE AP9475 at one of our client site. Now our client requires integration of the Access control and CCTV with DCE.
Here we are using the Hikvision brand for CCTV and ACS. Please share the procedure if it is possible.
Need your swift response.
Justine
Crewman Justine Crewman
Crewman
Posted: ‎2024-01-01 11:25 PM
893
Hi, StruxureWare DCE is only compatible with Netbotz appliances AFAIK. Only the cameras pods that can be added to the appliance can be used for Surveillance.
I think a similar question as raised a few years back:
https://community.se.com/t5/EcoStruxure-IT-forum/Hikvision-NVR-support-on-DCE/td-p/212619
Justine
Crewman
894
shoaibmaqsood52
Lieutenant JG
Posted: ‎2024-01-02 04:43 AM
In response to Justine
885
Hi justine,
Kindly advise if Hikvision Access control is compatible with DCE or not?
Justine
Crewman
Posted: ‎2024-01-08 09:19 PM
In response to shoaibmaqsood52
Hi, No. As far as I know, access control is also limited to Netbotz appliances only.
