Posted: 2020-07-03 04:32 AM . Last Modified: 2024-04-08 11:38 PM
(CID:106210825)
Posted: 2020-07-03 04:32 AM . Last Modified: 2024-04-08 11:37 PM
I'd also add that existing genomes can be modified to fit your needs on your own system for custom equipment or other items not found in the Genome. This is a fairly easy process and is outlined in our documentation here: https://dcimsupport.apc.com/display/public/UADCO8x/Working+with+the+genome+library+and+genomes as well as here: https://dcimsupport.apc.com/display/public/UAOp74/Configuring+Equipment+not+Available+in+the+Genome+...
Thank you!
-Jeff
(CID:106891039)
Hi Alper,
The Genome Library is updated with each new DCO release.
You can use the Device Support link to request a Genome for devices that are not already supported.
Regards
John T
(CID:106890995)
Thank you!
-Jeff
(CID:106891039)
Posted: 2020-07-03 04:32 AM . Last Modified: 2023-10-31 11:00 PM
