Hello could we insert DCO on Ap94vmact
  • Hello could we insert DCO on Ap94vmact
129
72
Posted: ‎2020-07-05 04:09 PM . Last Modified: ‎2024-04-03 05:12 AM
1287
(CID:137733192)
  • Data Center Operation
1287
Hi Afsaneh,
AP94VMACT is an activation key (license) for StruxureWare Data Center Expert (DCE) virtual machine.
This license (activation key) can only be installed on DCE virtual appliance.
DCO is a different software, for more details please see the following page(s):
User Assistance for StruxureWare Data Center Operation 8.x
Kind regards
(CID:137733383)
Replies 9
1288
Hi Afsaneh,
Kind regards
(CID:137733383)
Dear Jef,
Thanks for your following. My question is about after installing virtual DCE, please imagine we have DCE which is installed via ova and AP94VMACT and it works now. Then we want to insert DCO license in our DCE, is it ok? or we have to insert DCO license on hardware DCE server such as AP9475?
Best Regards
(CID:138807529)
Posted: ‎2020-07-05 04:10 PM . Last Modified: ‎2024-04-03 05:12 AM
and could you please let me know which OS do you suggest for installing ova and ap94vmact?
(CID:138807436)
Hi Afsaneh,
StruxureWare Data Center Expert (DCE) virtual appliance can be installed on VMware. After the installation, to activate the appliance, you would need to install ap94vmact activation key.
DCO is a different software, and must be installed on a dedicated server.
DCO is shipped with its operating system (CentOS) and can be installed both on a physical server an/or on a virtual environment (VM). For system requirements please see the following page: System requirements
Kind regards
(CID:138807535)
Dear Jef,
We have DCE AP94vmact on a VM and we want to use DCO, what can we do after purchasing the DCO license? is it just active the dco license key in our DCE?
Because I want to use DCO but I don't know whether I can active it on DCE ap94vmact or it needs a hardware server such as ap9475? I want to know where I have to insert the DCO key license? Is it necessary to have an AP9475 hardware server or a dce ap94vmact is ok?
could you please more explain about a dedicated server for DCO? as I knew for installing a DCO we need AP9475, and then we have to activate the license key of dco in the dce (ap9475). Is it right for the installing of the DCO?
and please excuse me for these simple questions. Thank you so much indeed.
(CID:138808446)
Hi Afsaneh,
DCO cannot be activated on DCE.
(DCO dose not require similar activation license as DCE).
DCO needs to be installed on a hardware sever or it can also be installed on a virtual machine.
Here is a minimum server requirement:
CPU: at least 4 cores (we recommend 8 cores)
Memory: at least 16 GB RAM
hard disk/storage: at least 100 GB
After you have installed DCO on a server, then you can add DCO related licenses:
DCO license (basic license)
Capacity license
Change license, etc.
Kind regards
(CID:138808527)
Thank you so much for your perfect answer, finally I could understand. and could you please send me a link address for downloading DDF files for existence DDF file on APC site?
(CID:138810052)
Hi Afsaneh,
You are are most welcome.
New DDF file(s) can be requested at Device Support site: http://sxwhelpcenter.ecostruxureit.com/devices
Kind regards
(CID:138810257)
Posted: ‎2020-07-05 04:10 PM . Last Modified: ‎2023-10-22 02:16 AM
