HP OneView integration and Asset Audit
  • HP OneView integration and Asset Audit
129
72
Posted: ‎2020-07-04 07:30 PM . Last Modified: ‎2024-04-04 11:12 PM
921
If we have a blade enclosure from HP OneView that is associated to its counterpart in Data Center Operation, what will the Asset Audit report then show if a blade is moved?
  1. Someone moves the blade from one position to another (same or different enclosure)
  2. HP OneView registers this event
  3. DCO reads the updated information from HP OneView and updates the model accordingly
What will the Asset Audit report of the blade and the enclosures then show?
Thanks!
(CID:132657433)
  • Data Center Operation
Hi Christian,
Unfortunately I don't have access to such/described setup to test and provide a clear answer, but I think if DCO gets the updates from the integrated HP Oneview, then the asset audit reports may contain information about the events (Added, Moved, Removed device). Obviously those reports/events may not contain 'user name' (so user name filed may be empty).
Kind regards
(CID:132659043)
Hi Christian,
Kind regards
(CID:132659043)
Posted: ‎2020-07-04 07:30 PM . Last Modified: ‎2023-10-22 02:14 AM
