Posted: 2020-07-03 09:14 AM . Last Modified: 2024-04-08 03:36 AM
Cannot seem to find a way to simply export a list of configured devices in DCE. Am I missing something?
Ed
(CID:110008573)
Ed,
To export a device list from Data Center Expert:
1) Open the Data Center Expert client.
2) Navigate to the Monitoring perspective (button).
3) Navigate to the Device View pane.
4) In the upper-right corner will be a folder with a green arrow that can be used to export the current device view. You can export as a CSV or TXT file.
NOTE: This is depending on what is currently showing in the device view pane, so ensure that you have either select all devices or a specific device group within the Device Groups pane first.
Cory
(CID:110008575)
Dear Ed,
FYI
Bala
(CID:110008674)
Posted: 2020-07-03 09:14 AM . Last Modified: 2023-10-22 02:07 AM
