GNOME correction request for Oracle Sun Rack II PDUS
  • GNOME correction request for Oracle Sun Rack II PDUS
127
65
Posted: ‎2020-07-05 07:24 PM . Last Modified: ‎2024-04-03 02:40 AM
934
For Struxureware version Version: 8.2.7-77203-e6c65c
How can we request a technical properties correction on "GNOME" for the listed devices:
Oracle Sun Rack II Power distribution Unit (RMII) (7078658) & Dual Feed (7078659).
Three Phase PDUS
Power ports on the PDUs on Schnieder GNOME - power phase selections available = shared phases - ie. L1-L2, L2-L3, or L3-L1. Where in actuality the PDU ports are grouped for one of the 3 power Phases single phase -either L1, L2, or L3 - no phase combinations.
Phase 1  for single source fed PDU p/n 7078658 is Group 0 ports
Phase 2  for single source fed PDU p/n 7078658 is Group 1 ports
Phase 3 for single source fed PDU p/n 7078658 is Group 2 ports
Phase 1  for dual source fed PDU p/n 7078659 is Group 0, 3 ports
 Phase 2  for dual source fed PDU p/n 7078659 is Group 1, 4 ports
 Phase 3  for dual source fed PDU p/n 7078659 is Group 2, 5 ports
Brian Muckian
Senior Analyst
Data Center Operations
1-779-231-6587 (work)
(815) 790-6329 ( cell )
(CID:143758796)
  • Genome
Hi Brian,
Thank you for your input.
I recommend you update the setup with the latest Genomes package that might solve your needs with a Genome introduced in September 2018: Oracle RMII 15kVA-3 LV PDU.
Here you can find information about available update packages and changes introduced for each release, how to get access to the packages and how to apply them in DCO: https://sxwhelpcenter.ecostruxureit.com/display/download/Genome+Library
Best regards,
Bartek Orlowski, Software developer
(CID:143760461)
Posted: ‎2020-07-05 07:24 PM . Last Modified: ‎2023-10-22 02:06 AM
