Full Backup is failing on DCE 7.3.0.96
  • EcoStruxure IT forum
  • Full Backup is failing on DCE 7.3.0.96
126
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-04 01:33 AM . Last Modified: ‎2024-04-05 04:05 AM
730
i am getting the below error when i try to run a full backup on dce (7.3.0.96)
"the selected Backup is idle"
please advise how to troubleshoot this backup failure and where can i find the related logs.
Thanks.
(CID:126170869)
Hi Charbel,
I've not seen an error message like that pop up when you try to run the backup but I have seen it as a current status:
Have you tried rebooting the server?
Have you tried a different backup?
Can you create and run a new backup?
Has anything changed with respect to the target directory?
Is the target directory full?
Can you run a config backup?
Perhaps showing with a screenshot, when you click the "start backup" button, does this idle message simply appear?
Perhaps you could also show a screenshot of the page as I did to show any oinfo such as last result.
Is this a scheduled backup?
7.3.0 is a little old, is there a reason you've not updated to 7.4.3?
Steve.
(CID:126170939)
Hi Charbel,
Steve.
(CID:126170939)
Posted: ‎2020-07-04 01:33 AM . Last Modified: ‎2023-10-22 02:06 AM
