Posted: 2020-07-03 05:12 AM . Last Modified: 2024-04-08 11:25 PM
Hi all, is there a way to flush the DNS cache on a StruxureWare DCE server?
We replaced a faulty UPS with a new unit and reused the old IP but with a new hostname. However even with removing the device from DCE and adding it again it's still showing the old hostname.
A server reboot seemed to sort it out but I'm just wondering if there's another way to clear the cache without needing to reboot.
Cheers.
(CID:107448323)
Hi Jamie,
There is no command to flush the DNS on the DCE server, so a reboot would be required.
Regards
(CID:107448341)
Posted: 2020-07-03 05:13 AM . Last Modified: 2024-04-08 11:25 PM
You can connect to console with ssh and you can try that command. "service nscd restart"
(CID:107448578)
Posted: 2020-07-03 05:13 AM . Last Modified: 2023-10-31 10:59 PM
