Fiber Patching
  • Fiber Patching
129
72
Posted: ‎2020-07-02 12:48 PM . Last Modified: ‎2024-04-09 11:43 PM
832
Fiber Patching
When will 7.5 be released?  I notice the answer with patch panels and not sure if the fiber housing will be handle the same why I am asking the below...
With the release of 7.5 will this work within a fiber housing as well? I need to connect 2 modules with in same housing and 7.4.5 does not allow me to do this.
(CID:96764949)
  • Data Center Operation
Posted: ‎2020-07-02 12:48 PM . Last Modified: ‎2024-04-09 11:42 PM
832
7.5 will address the issue you are having basically allowing interconnections between two ports on the same equipment regardless of the connection type.
The next release is available shortly - your local Schneider contact will notify when you can download it.
/Anders
(CID:96765031)
833
/Anders
(CID:96765031)
Got 7.5 and it is now working. Thanks
(CID:96765360)
Posted: ‎2020-07-02 12:48 PM . Last Modified: ‎2023-10-31 10:59 PM
