Failed to restore a backup file to DCE 7.2.1
  • Failed to restore a backup file to DCE 7.2.1
129
72
Posted: ‎2020-07-02 11:16 AM . Last Modified: ‎2024-04-10 12:37 AM
888
I am tried to restore a backup file by windows share to DCE 7.2.1 but no file showing on the table.
Best Regards,
(CID:94602921)
Replies 5
888
Hi Ahmad,
You can only restore a backup to the same server version. If the backups contained in the share are older than v7.2.1 or newer than v7.2.1, it will not be shown as a backup you can use to restore your DCE server with.
Did you check the location of the share and see what backup versions exist?
Breda
(CID:94602925)
Posted: ‎2020-07-02 11:16 AM . Last Modified: ‎2024-04-10 12:36 AM
Yes, it's the same version ( backup_Expert_20141225115315_7.2.1).
(CID:94602993)
Hi Ahmad, Is this a DCE VM or a physical DCE you are using? Was the backup created on a DCE VM or physical DCE? Was this backup created on a different DCE other than the one you are importing it into? Is this windows backup on a remote machine or your local machine? Was this backup ever moved from the original location? Did you try and move the backup from the backup location to a share on your laptop? Regards, Breda
(CID:94602994)
Hi Breda, Thanks for your support... Please find the below: This is the DCE VM , backup file created on the DCE VM, this backup created on a different DCE But it's same version, it's local machine, NO, NO, I didn't Best Regards, Ahmad
(CID:94603000)
Posted: ‎2020-07-02 11:16 AM . Last Modified: ‎2023-10-31 10:58 PM
