Excel Import Set Front or Rear Mounting
  • Excel Import Set Front or Rear Mounting
129
72
Posted: ‎2020-07-05 09:36 PM . Last Modified: ‎2024-04-03 12:45 AM
878
Is it possible to specify between front/rear u mounting position when using Excel import?
(CID:147785073)
  • Data Center Operation
Hi Mark!
Yes. It's set equipment to the front side of the rack by default.
If you need to mount device to back position, you need to add "B-" prefix to unit position. I.e. B-32 means that device will be installed to 32 U-position at back side of the rack.
(CID:147785081)
Hi Mark!
(CID:147785081)
Posted: ‎2020-07-05 09:36 PM . Last Modified: ‎2023-10-22 02:03 AM
