Error: The currently displayed page contains invalid values
Showing results forΒ
Did you mean:Β
  • Error: The currently displayed page contains invalid values
129
72
Posted: β€Ž2020-07-04 04:52 PM . Last Modified: β€Ž2024-04-05 12:06 AM
1622
On our DCE I am getting this error trying to access "Network Settings" and Server Access". The syste...
(CID:130099263)
Posted: β€Ž2020-07-04 04:53 PM . Last Modified: β€Ž2024-04-05 12:06 AM
1619
Hi all
We actually did contact technical support and arranged for remote access to our DCE. The engineer was able to solve the issue. According to engineer it was an issue with ssl.conf file.
Cheers
(CID:132647054)
Replies 6
1619
Hi Adrian,
You'll need to contact technical support directly. If you can get a remote session going with them, they should be able to access the system's root and correct the issue. We can't provide root access so that's the only way to resolve it short of restoring and manually re-configuring (no import of the backup).
Steve
(CID:130099278)
Thanks Steve...will give it a try.
(CID:130682416)
Dear Adrian Jeitziner,
Tell us, please, you were able to solve the problem or not? And if they could solve, how?
With respect.
(CID:132647016)
1620
Hi all
Cheers
(CID:132647054)
Many thanks for the fast reply πŸ˜€.
With respect.
(CID:132647060)
Posted: β€Ž2020-07-04 04:53 PM . Last Modified: β€Ž2023-10-22 02:03 AM
