Posted: 2020-07-05 01:11 PM . Last Modified: 2024-04-04 12:37 AM
Hi Have an error on my server keep on occurring , can any one help me out to erase this issue.
Attach is the picture of my server error log
(CID:134686814)
Dear Shaik Mahboob Ali,
In short, these errors are caused by the fact, that one or several of your NetBotz appliances are trying to log in to the DCE-server with incorrect login/password.
Probably, recently you or someone changed the login/password on the DCE-server, which was usually used by your NetBotz appliances for Post Only Mode. For more details on this mode of operation of the NetBotz appliance, please refer to FA158263 - Configuring Post-only Mode for Netbotz Version 2 and 3 Appliances.
Conclusion: double check the correctness of the NetBotz appliance settings in the APC Advanced View software. To do this, select the menu item Tools -> Advanced -> Advanced View POST-only mode... and in the Advanced View POST-only mode Configuration window check the validity of the login/password for your DCE-server. For more information on debugging in this case, you can read in topic .
Hope this helps you.
With respect.
(CID:134687280)
Good day
I have checked and verified the (double check the correctness of the NetBotz appliance settings in the APC Advanced View software. To do this, select the menu item Tools -> Advanced -> Advanced View POST-only mode... and in the Advanced View POST-only mode Configuration window check the validity of the login/password for your DCE-server)
I have no entries in the Advanced View POST-only mode Configuration window
is there anything else i can verify ?
Kind regards
(CID:136644568)
Dear juice,
In that case, see my comment on this issue:
But if all these methods do not work for you at all (?why I don’t know?), then I can offer the last radical method: restore the NetBotz-4.x appliance to factory defaults. How to do this remotely without losing the IP configuration is well written in topic I want to reformat my Netbotz Appliance.
With respect.
(CID:136644612)
Posted: 2020-07-05 01:11 PM . Last Modified: 2023-10-22 02:03 AM
