Email failure
  • Email failure
129
72
Posted: ‎2020-07-05 07:31 PM . Last Modified: ‎2024-04-03 02:37 AM
1042
Email failure
Hi, I have a DCE 7.5.0.62 that according with my costumer the email settings are all correct but stil he cant send any email.
We already made a reset to the server but the issue remains
Is any test that we can do to sorted out this issue ?
(CID:143760331)
I would use Gmail for testing. If you don't have a Gmail account already, it's free and easy to set one up.
Settings you need for the device.
smtp.gmail.com
Port 587
SSL enabled
Username and password.
Depending on the environment you may need to open port 587 outbound on the customer firewall/UTM.
(CID:144311182)
smtp.gmail.com
Port 587
SSL enabled
(CID:144311182)
Thank you, for your advice I will confirm that with my costumer
(CID:144311188)
Posted: ‎2020-07-05 07:31 PM . Last Modified: ‎2023-10-22 02:00 AM
