Easy SRVS integration into Data Center Expert
Showing results forΒ
Did you mean:Β
  • Easy SRVS integration into Data Center Expert
126
65
Posted: β€Ž2020-07-05 05:45 PM . Last Modified: β€Ž2024-04-03 03:15 AM
838
Is it possible to integrate the Easy SRVS UPS Series within the Data Center Expert?
I see that the APVS9601 SNMP Network Management Card would be required but I'm not sure if the DDF already exists or not.
Thanks a lot
(CID:140711444)
  • DDF
Replies 6
Hi Antonio,
Yes.  It looks like this card uses the generic RFC1628 SNMP UPS MIB, which is included with the DCE installation.
Jake
(CID:140711482)
Yes, you could. I already connected SRV UPS to DCE and Ecostruxture IT Expert
(CID:140711589)
Dear Antonio Racioppoli,
Tell us, please, did you solve your question or not?
With respect.
(CID:141269221)
Yes I confirm it was solved
(CID:141269313)
Ok, thanks for the good feedback πŸ˜€.
(CID:141269335)
Posted: β€Ž2020-07-05 05:46 PM . Last Modified: β€Ž2023-10-22 01:58 AM
