ETL import/Export not working
  • ETL import/Export not working
129
72
Posted: ‎2020-07-05 04:39 PM . Last Modified: ‎2024-04-03 04:25 AM
1093
ETL import/Export is not working
The import CSV files with data can be seen in the webamin in the import folder,  however, I cannot see the data in the DCO client under device association/ETL integration import folder?
For the export, the csv files arent created.?
All ETL services are running
(CID:138811287)
  • Data Center Operation
Replies 5
Hi Paolo,
It used to work, right? Do you know what changes have been applied, that might cause this not working issue?
Would it possible to ask for the following data:
  • screen captures illustrating the issue(s) + description of the applied changes
  • backup file
  • server logs
I will send you an invite to mu =S= box folder, so the data safely can be shared with me, thanks.
Kind regards
(CID:138811461)
Hi Jef
Thank you for coming back to me.
I have uploaded to the shared folder the following.
  1. Screen captures but description issues
  2. Latest back up file (30th).  Back up file when the ETL stopped working (24th) and back up file I used after we upgraded the DCO (9th)
  3. Server Logs
Please let me know if you need any more information.
Kind regards
Paolo
(CID:138812131)
Hi Paolo,
Many thanks - I will get back to you as soon as possible,
Kind regards
(CID:138812133)
Hi Paolo,
A file that may resolve the integration issue is created and ready for you (that needs to be uploaded to your DCO, /data/pentaho/export folder). I will send you a direct message (by email) as well, thanks.
Kind regards
(CID:138812483)
Posted: ‎2020-07-05 04:40 PM . Last Modified: ‎2023-10-22 01:58 AM
