Posted: 2020-07-05 04:36 PM . Last Modified: 2024-04-03 05:02 AM
After upgrading to 8.2.7 my ETL export database is no longer functioning.
The initial ETL export was successful. The error only appears when merging/updating data. The below is the error received:
2019-01-28 10:00:02,769 ERROR [0CGZi4oBRhy0fy8dpYeBAQ] [datacenterservices] [org.pentaho.di] (swoAsset_v2.0.0 - Merge) Merge - Unexpected error
2019-01-28 10:00:02,769 ERROR [0CGZi4oBRhy0fy8dpYeBAQ] [datacenterservices] [org.pentaho.di] (swoAsset_v2.0.0 - Merge) Merge - org.pentaho.di.core.exception.KettleException:
Invalid layout detected in input streams, keys and values to merge have to be of identical structure and be in the same place in the rowsThe data type of field #16 is not the same as the first row received: you're mixing rows with different layout. Field [ci_max_power_draw Number(15)] does not have the same data type as field [ci_max_power_draw BigNumber(17, 17)].
at org.pentaho.di.trans.steps.mergerows.MergeRows.processRow(MergeRows.java:92)
at org.pentaho.di.trans.step.RunThread.run(RunThread.java:60)
at java.lang.Thread.run(Thread.java:748)
Caused by: org.pentaho.di.core.exception.KettleRowException:
The data type of field #16 is not the same as the first row received: you're mixing rows with different layout. Field [ci_max_power_draw Number(15)] does not have the same data type as field [ci_max_power_draw BigNumber(17, 17)].at org.pentaho.di.trans.step.BaseStep.safeModeChecking(BaseStep.java:1861)
at org.pentaho.di.trans.steps.mergerows.MergeRows.checkInputLayoutValid(MergeRows.java:265)
at org.pentaho.di.trans.steps.mergerows.MergeRows.processRow(MergeRows.java:88)
... 2 more2019-01-28 10:00:02,769 INFO [0CGZi4oBRhy0fy8dpYeBAQ] [datacenterservices] [org.pentaho.di] (swoAsset_v2.0.0 - Merge) Merge - Finished processing (I=0, O=0, R=2, W=0, U=0, E=1)
2019-01-28 10:00:02,769 INFO [0CGZi4oBRhy0fy8dpYeBAQ] [datacenterservices] [org.pentaho.di] (swoAsset_v2.0.0 - Merge) swoAsset_v2.0.0 - swoAsset_v2.0.0
2019-01-28 10:00:02,769 ERROR [0CGZi4oBRhy0fy8dpYeBAQ] [datacenterservices] [org.pentaho.di] (QuartzSharedThreadPool-1 M/Mur0csSGqQjTGc1EWLlw) swoAsset_v2.0.0 - Errors detected!
2019-01-28 10:00:02,770 ERROR [0CGZi4oBRhy0fy8dpYeBAQ] [datacenterservices] [org.pentaho.di] (QuartzSharedThreadPool-1 M/Mur0csSGqQjTGc1EWLlw) swoAsset_v2.0.0 - Errors detected!
DCO updated from 8.0.2 to 8.2.7.
Database Driver: net.sourceforge.jtds.jdbc.Driver
Dialect: org.hibernate.dialect.PostgreSQL94Dialect / SQLServerUnicodeDialect
DB Destination: MS SQL Server 2017
(CID:138810569)
Posted: 2020-07-05 04:37 PM . Last Modified: 2024-04-03 04:26 AM
Hi (DataCenterServices),
This seems to be a known issue, where an ETL export to SQL server may fail after the second transformation.
This issue is fixed in the latest version of DCO (currently 8.2.12),
Kind regards
(CID:138810772)
Posted: 2020-07-05 04:36 PM . Last Modified: 2024-04-03 04:26 AM
I usually see advice to delete the External system, then delete the export DB, then recreate export DB and then the external system. That has solved many issue for me in the past.
Cheers
Ed
(CID:138810660)
Are you by chance exporting to an external ETL database, perhaps a MS-SQL version by chance?
Regards
Greg Sterling
(CID:138810679)
Yes, sorry. I see you mentioned its an external ETL ms-sql database. There may be a transformation update which can be provided to resolve this issue. I have seen this at least one other customer. I'll ask dev if there's a file which can be shared.
A fix for this should also be in the latest DCO release, 8.2.12.
Regards
Greg Sterling
(CID:138810680)
Kind regards
(CID:138810772)
Thanks for the input. Upgrading DCO from 8.2.7 to 8.2.12 resolved the ETL issue.
Best
(CID:138811665)
Sounds great! many thanks for the update.
Kind regards
(CID:138811667)
Posted: 2020-07-05 04:37 PM . Last Modified: 2023-10-22 01:57 AM
