ETL data export to internal DB
Showing results forΒ
Did you mean:Β
  • ETL data export to internal DB
129
72
Posted: β€Ž2020-07-04 11:32 PM . Last Modified: β€Ž2024-04-04 02:31 AM
1395
I'm still new to ETL and trying to export data using DCO ETL but I cannot find any data on export data base.
I took the following procedures.
  1. Created export data as internal database based on the documents below.
    http://sxwhelpcenter.ecostruxureit.com/display/public/DCIMDEVELOPER/ETL+Database+Configuration
  2. From DCO Client, I have configured ETL integration. I choose "No transormation v 1.0.0" for transformation.
  3. Using spoon client, I could connect with the export data base and see the table definitions but cannot find any data record in it.
What's steps are additionally required to export data?
P.S.
 In case of importing data,  I could successfully import data and confirm the records in import database.
Akihiro Yamagami
(CID:134031178)
  • Data Center Operation
1394
The etl export follow scheduled export time set during configuration in dco.
You can force the external system,from dco client under associate device,right click choose synchronize external data,so you can see those data.
(CID:134031197)
Replies 6
1395
(CID:134031197)
Posted: β€Ž2020-07-04 11:33 PM . Last Modified: β€Ž2024-04-04 02:31 AM
Hello
Thank you for your comment! I setup export database yesterday with 1 hours schedule and also sync the data. But, I cannot see any data record...
I also attach the screenshots.
  • Webmin setting
  • DCO client settings
  • sync on DCO client
  • records on spoon (sorry, includes local characters)
  • records on psql (configuration_item)
(CID:134031270)
Pictures really say a thousand words πŸ˜€
Use the other option, swoExportJob when you set up the test for export like below:
I was using pqadmin to test out, but the idea is you can see data from the export db tables.
(CID:134031285)
Hello Christopherus!
Thank you for your quick response.  I could successfully see many records!!! Thank you.
Akihiro Yamagami
(CID:134031308)
Posted: β€Ž2020-07-04 11:33 PM . Last Modified: β€Ž2024-04-04 02:30 AM
This topic will be also helpful for entire community. So, I will make this topic to "public".
(CID:134031364)
Posted: β€Ž2020-07-04 11:33 PM . Last Modified: β€Ž2023-10-22 01:57 AM
