ETL data export: network connections description and IP Address
  • ETL data export: network connections description and IP Address
129
72
Posted: ‎2020-07-05 05:10 PM . Last Modified: ‎2024-04-03 04:14 AM
1013
I would like find in the ETL export data, the description and IP Address of network connections but I did not find anything in the table relation_endpoint_property, relation_property, port_configuration
Does someone know if these information are available in the ETL Export data ?
In addition for port without connections, we would like to get the port description.
We are about to configure all the network connections but as step 1 we have inventoried the Free ports
Note: we use DCO 8.2.12 and the ETL job swoExportJob_v2.0.0
Best Regards
Yannick
(CID:140217413)
  • Data Center Operation
Posted: ‎2020-07-05 05:11 PM . Last Modified: ‎2024-04-03 04:14 AM
Hi Yannick,
I had a quick look, it appears that the network connections "Description" and "IP Address" is not exported to the ETL export database.
Kind regards
(CID:141264722)
Hi Yannick,
Kind regards
(CID:141264722)
Posted: ‎2020-07-05 05:11 PM . Last Modified: ‎2023-10-22 01:57 AM
