ETL Export - How to identify rear cable connections? module name?
  • EcoStruxure IT forum
  • ETL Export - How to identify rear cable connections? module name?
124
110
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-02 05:03 PM . Last Modified: ‎2024-04-09 02:36 AM
644
Hi Support team,
DCO 7.5 SP2 ETL Export  configuration_item_relation table
How do I identify if a patch panel connection is to the front or the rear of a patch panel port?
I can see some info in cir_id and one end of the module name.
(CID:103586488)
  • Data Center Operation
Replies 4
Posted: ‎2020-07-02 05:03 PM . Last Modified: ‎2024-04-09 02:35 AM
644
Hi Ed,
I'd say, if the connection is between two patch panels, then it's on the rear. I would need to create a setup and export it to identify precisely whether the "Rear" information is directly available. Maybe you have an export database I can connect to check? 😀
-Guillaume
(CID:104173748)
Thanks Guillaume
Thread taken off line
(CID:104173820)
DCO 7.5 SP3 appends "true" to cir_id in configuration_item_relation, e.g.
select cir_id, ci_id_a, ci_id_b
from configuration_item_relation
where cir_id like '%true';
appears to give you all the rear to rear connections
(CID:104173792)
Posted: ‎2020-07-02 05:03 PM . Last Modified: ‎2023-10-31 10:57 PM
