Posted: 2025-06-12 11:53 AM
Looking to find out what model and brand of Managed Switches work well with EBO. We started off using a Plant brand switch when we started EBO and transitioned to the Schneider TCSESB083F23F0, using it exclusively over the past couple of years. However, we just learned from Schneider that the TCSESB model switch is not supported by EcoStruxure and it only allows one verified RSTP loop per switch. Is anyone aware of a Managed Switch that is either supported by EBO or that allows the user to setup multiple verified RSTP loops on the same switch?
Posted: 2025-06-12 01:19 PM
We use Phoenix Contact FL 2000 8 port switch. Din rail mountable. Very reliable. Easy Set up.
Posted: 2025-06-13 04:51 AM
Thanks for the reply Bsnider! Have you had success running multiple RSTP loops from the same switch with the Phoenix?
Posted: 2025-06-13 06:09 AM
Yes, you can run up to 3 per 8 port switch.
3 Home runs
3 Returns
1 port for switch to switch or switch to AS
1 port left for misc connections
