Duplicate sensor readings
  • Duplicate sensor readings
129
72
Posted: ‎2020-07-05 10:25 PM . Last Modified: ‎2024-04-03 12:28 AM
747
Why would DCE show duplicate supply air, return air, rack inlet temperature sensor readings from an ACRC100/103 series cooling unit? Some readings are identical. Some differ. Some are the same but displayed differently.
Return air = 80.1°F
Return air = 75.7°F
Supply air = 60°F
Supply air = 60°F
Rack inlet = 107.1°F
Rack inlet 1 = 70°F
Unit run hours = 4.0 run-h
Unit run house = 4.0 h
Air filter run hours = 1,000  run-h
Air filter run hours = 1,000 h
Cool demand = 1.0 kW
Cool demand = 1,000 W
(CID:149292377)
Hi steve, i had similar case in Air DX Amico, in that case I chose a DDF, that i was recommended by the mark. But in time that installed, i´ve seen different parameter than not have value or be zero. Why?, because they are general. Ive given you the web than i pick the mib for the my air condition.
 https://help.ecostruxureit.com/devices
or
https://www.apc.com/shop/pe/es/products/Unidad-de-agua-helada-InRow-RC-de-300-mm-100-120-V-50-60-Hz/...
(CID:149292419)
Posted: ‎2020-07-05 10:25 PM . Last Modified: ‎2023-10-22 01:57 AM
