Don`t run DCO 8.0.4 after install
  • Don`t run DCO 8.0.4 after install
127
Posted: ‎2020-07-03 02:02 PM . Last Modified: ‎2024-04-08 01:26 AM
882
i try to install one DCO 8.0.4 in Vmware.
I followed the instructions of the installer, but when finishing and rebbot.  S.O. Centos works fine, but nothing else. DCO is not in the server.
What I can do?
What is the specification of virtual machine, network adapter, vmware version ?, disk, processor and memory meets it according to the requirements
(CID:114233147)
  • Data Center Operation
Replies 6
882
Hi Miguel,
I guess it might be something to do with the network interface that might need to be configured manfully (during the installation process on VMWare).
During the installation and “Network & Host Name” configuration it is important to select the Device interface that contains MAC address. The highlighted steps are shared here:
https://dcimsupport.apc.com/questions/114233340/dco-8.x-installation-on-vmware-manually-configuring-...
You might want to re-try the installation, but this time with manual IP configuration.
Hope this helps,
Kind regards
(CID:114233356)
Hi jef
I use manual IP but there isn´t that option, it appear empty
I put mac address
My Vwware config
and my ethernet config obtained after install
I reinstall but no changes, S.O. work fine, Operattions don´t work
(CID:114233613)
Hi Miguel,
What is the version/type of your VMware?
Would it be a correct assumption that this might be a VMWare workstation?
Kind regards
(CID:114233629)
Posted: ‎2020-07-03 02:03 PM . Last Modified: ‎2024-04-08 01:25 AM
ESxi 5.5 vmware 8
would you connect to my computer and have a look, to try detect the issue?
(CID:116919281)
Hi Miguel,
Just sharing an update that some days ago we managed to apply a successful installation. Additional to manual IP configuration, we had to do an off-line installation (apparently due to local network policies server was unable to access the internet during the installation).
Kind regards
(CID:116919284)
Posted: ‎2020-07-03 02:03 PM . Last Modified: ‎2023-10-22 01:56 AM
