Posted: 2022-01-18 01:58 AM . Last Modified: 2022-01-18 02:03 AM
Does NBWL075 have a POE in a Private LAN port?
Can i connect one CameraPod165 directly to Private LAN port of Netbotz 755 Room Monitor?
In a manual for nb750 stated accurately, that 4 Private Lan Ports have PoE,
but in a nb 755 manual there is no such information aboute Private LAN Port:
Posted: 2022-01-18 07:33 AM . Last Modified: 2022-01-18 08:13 AM
Hi @amyshanov ,
Yes, the private LAN port on the 755 is POE.
Initially I thought the unit (itself powered by POE type2) could power 1 camera, I have since found out that if powered properly, it can power both the docked camera as well as one camera connected to the private LAN.
Steve
Posted: 2022-01-18 08:03 AM . Last Modified: 2022-01-18 08:17 AM
You mean, that to connect two cameras to DCE i must build this desigion:
It seem so strange!
Posted: 2022-01-18 08:10 AM
Hi @amyshanov ,
I re-verified my previous comment (and will correct it. I am now told that if the 755 is powered properly (POE type 2 @ approximately 36w), it can handle the mounted camera and one on the private LAN without additional power.
DCE is secondary in that config.
Steve
