Does ITO support IE 11?
  • Does ITO support IE 11?
126
65
Posted: ‎2020-07-02 11:32 PM . Last Modified: ‎2024-04-09 01:11 AM
828
A client of mine is currently having issue with ITO on IE11. The issue seems to be related to the certificate. There are no issues when using Firefox or Chrome however policy dictates mandatory use of IE11. Any suggestions?
(CID:105464969)
  • Data Center Operation
  • IT Optimize
828
Hi Kevin,
ITO is currently supported on IE 11, here is a capture from my test setup:
Most likely the customer issue is related to the security/privacy settings on the default browser (IE11), and managed by the customer system administrator. Try to add the ITO server to the browser "Trusted sites" (Tools > Security> "Trusted sites") and see if that helps.
Kind regards
(CID:105465000)
Replies 4
829
Hi Kevin,
Kind regards
(CID:105465000)
Actually very embarrassing how it was resolved. =( I reset the Internet Explorer settings and it worked fine afterwards.
(CID:105465261)
Hi Kevin, Nice to hear that it is resolved & many thanks for sharing. Kind regards
(CID:105465271)
Posted: ‎2020-07-02 11:32 PM . Last Modified: ‎2023-10-31 10:55 PM
