Does DCO 7.4 support half rack, quarter rack or any other height racks?
  • EcoStruxure IT forum
  • Does DCO 7.4 support half rack, quarter rack or any other height racks?
125
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-02 08:04 AM . Last Modified: ‎2024-04-10 01:36 AM
802
I 'm trying to make DCO support half rack like AP3200.
If it is ok, I would like to know how I can set other than genome.  I cannot find AP3200 in genome
(CID:89063878)
  • Data Center Operation
Replies 6
Posted: ‎2020-07-02 08:05 AM . Last Modified: ‎2024-04-10 01:36 AM
Hi Yoshinobu, we will look into it, thanks for posting.
(CID:89063928)
Hi Yoshinobu,
Workaround exists for this. You would want to go for a generic rack & before dragging it into the layout, you can reset as many U positions you want with any other dimension related properties. However, we will welcome your inputs if you suggest to associated any more properties or to add any more equipment to Genome.
Should you have any lists, you can forward it to us to consider if those can be added to the Genome.
(CID:89063990)
Posted: ‎2020-07-02 08:05 AM . Last Modified: ‎2024-04-10 01:35 AM
we have a similar issue. We have full racks separated in quarter and half racks in our datacenter for Colo purposes. How can we put 4 Quarter Racks 11HE on top of each other?
Best regards
Johannes
(CID:89064247)
803
HI Johannes,
I believe you are going with Co-Lo licenses here. Anyway, the Co-Lo features are supported at cage level only. This is in view that, once the client enters his assigned cage, he should be able to access all his allocated assets. However, at rack level, the client should not have any access to the infrastructure that does not belong to him, or he might not want to access the things other than those allocated to him.
Anyway, workaround still exists for your scenario.
1>You might use multiple "tags" to assign multiple clients within the same racks. Option of Equipment browser could help you uniquely identify these segregated clients within the same racks. in similar way, you can also tag the rack PDUs as well if at all you are using separate for each client within the same racks.
2>In case if you want pictorial representation of your rack being allocated to various clients, you can make use of some non power objects to depict the client name plate.
I would personally recommend to got for Tagging he equipment as you can draw various kinds of reports in more efficient way when the equipment is tagged.
(CID:89064254)
Hi Johannes, Adding to Aniruddha's answer. At present the quarter and half racks are not supported in DCO. We are very much aware of the need for this functionality in terms of physically modelling the racks. I assume you have the colo license installed in your environment? If so there is a customer integration functionality that you might already be using/aware of. Otherwise have a look here: http://dcimsupport.apc.com/display/DCIMDEVELOPER/CustomerWebService This allows you to associate equipment to a specific customer. This goes all the way down to asset/server level. This means you could have a rack indicating the 4x11u and in there associate customers to the assets in the rack. You might also divide the rack into 4 by using e.g. a blanking panel to separate the rack.
(CID:89555250)
Posted: ‎2020-07-02 08:05 AM . Last Modified: ‎2023-10-31 10:55 PM
