Posted: 2020-07-03 04:31 AM . Last Modified: 2024-04-08 11:38 PM
The power panels need to be monitored and they are 250 meter far from the DCE switch, I am using Schneider gateway to convert from Modbus to Modbus TCP/IP ?
What is the solution here..
(CID:106210727)
Hi Piere
I think you could install EGX or Schneider Gateway closer to swtch because limitation on Ethernet cable, but 250 m still ok for modbus communication (lenght). Other Option, you could change ethernet cable with FO, but it will increase for the cost.
(CID:106210733)
Posted: 2020-07-03 04:31 AM . Last Modified: 2023-10-31 10:54 PM
