Discovering a SNMP v2 battery monitoring system in DCE ?
  • Discovering a SNMP v2 battery monitoring system in DCE ?
129
72
Posted: ‎2020-07-02 10:39 AM . Last Modified: ‎2024-04-10 12:48 AM
1297
Can someone tell me if there is a workaround to discover the Midtronics Cellguard battery monitoring system into DCE  ?
http://www.stationary-power.com/products/battery-monitoring-systems-cellguard/ups-telecom-standby-ce...
As today, this battery monitoring system supports only the SNMP v2, and trying to discover with SNMP v1 and V3 gives no result.
Thanks.
(CID:93915378)
1296
Hi Francois,
We do not support the discovery of 3rd party SNMPv2 devices (FA226273). This device according to the manual supports the Modbus protocol (Modbus RS-485 and optional Modbus TCP/IP). DCE supports Modbus TCP/IP as one of the discovery protocols. You would need to send an email to multivendorsupport@apc.com to get a DDF created to import it into DCE as it is a 3rd party device.  DCE uses this DDF to define the monitoring parameters for this device.
Breda
(CID:93915383)
Replies 6
1297
Hi Francois,
Breda
(CID:93915383)
Posted: ‎2020-07-02 10:40 AM . Last Modified: ‎2024-04-10 12:48 AM
Thanks Breda.
(CID:93915392)
Your welcome.
(CID:93915396)
Hi Breda, do you have list of 3rd Party Battery Monitoring System that your multivendor support have already used in DCE? Have you faced any issue during the integration despite the DDF import into DCE? Thanks!
(CID:93915397)
Hi Eimer, Unfortunately I don't have a list of 3rd party BMS's that we have created DDF's for. Once the DDF has been created based on all the information on the device sent to multivendorsupport (SNMPwalk, MIB, register map etc), there should be no problem importing the DDF into DCE. I only have seen problems integrating the DDF when the DDF has been modified or created by someone other than multivendorsupport.
(CID:93915398)
Posted: ‎2020-07-02 10:40 AM . Last Modified: ‎2023-10-31 10:54 PM
