Dew Point on 355 Camera showing wrong values
  • EcoStruxure IT forum
  • Dew Point on 355 Camera showing wrong values
124
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-04 03:04 AM . Last Modified: ‎2024-04-05 03:37 AM
796
Hi ,
Can some one assist me to understand the dew point sensor value showed on Netbotz camera value with below Humidity & Temperature.
Humidity :40%
Temperature :19.5 ° C
 Dew Point : 5.5 ° C
Is this Dew Point value is correct ? Is there a sensor to detect Dew Point or based on Temperature & Humidity Sensor value.
Regards
Shaik Mahboob Ali
(CID:126884616)
Dear Shaik,
Please refer our K-base ID: FA158136
https://www.schneider-electric.co.in/en/faqs/FA158136/
Dew-Point Calculations on the NetBotz Appliances
Product Line:
NetBotz
Environment:
NetBotz version 1 and 2
Cause:
Definition: Dew Point is the temperature at which condensations forms
Resolution:
When air comes in contact with a surface that is at or below its Dew Point temperature, condensation will form on that surface.
The following URL explains how the dewpoint is calculated:
http://www.lamtec.com/tb_dew_point_calculator.html
I hope this helps.
Bala
(CID:126884620)
Replies 4
Dear Shaik,
Product Line:
NetBotz
Environment:
Cause:
Resolution:
I hope this helps.
Bala
(CID:126884620)
Posted: ‎2020-07-04 03:05 AM . Last Modified: ‎2024-04-05 03:37 AM
795
Hi Balaraman Jagadeesan,
I cannot access the link
(CID:126884638)
Try this link..it is working for me.
https://www.lamtec.com/technical-bulletins/dew-point-table/
(CID:126884642)
Posted: ‎2020-07-04 03:05 AM . Last Modified: ‎2023-10-22 01:54 AM
