Device request contact information
  • Device request contact information
129
72
Posted: ‎2020-07-04 03:39 PM . Last Modified: ‎2024-04-05 12:29 AM
974
Does anyone know some contact information to the DDF team? I have tried to get some DDF files, but I don’t get any answer.
(CID:129410536)
Hi Gabor,
I have responded to both of your tickets. Check your inbox.
Glenn Martin
(CID:129411113)
Replies 4
Hi Gabor Novak,
Both files are available in the DDF library, kindly follow the below steps.
  1. Go to device Support
  2. Search your required DDF (NA96MGF3900Rmodule  - Socomec Countis E44)
  3. Then select "I Want it too"
  4. You can see the request status by going to your profile picture in the upper right and then select My Device Requests and download your DDF.
BR,
Rana
(CID:129410607)
Hi Gabor,
Glenn Martin
(CID:129411113)
@Rana
If you see the attached picture I have already done this.
@glenn
Thank you, I have it. 😀
(CID:129412026)
Posted: ‎2020-07-04 03:40 PM . Last Modified: ‎2023-10-22 01:53 AM
