DeDCE on hardware server not Starting up
  • DeDCE on hardware server not Starting up
126
65
Angwenyi
Lieutenant JG Angwenyi
Lieutenant JG
Posted: ‎2024-09-06 12:02 AM
1081
Dear Team,
Kindly, I have DCE on hardware server which customer reported on not starting up after restarting.
On further troubleshooting we found attached errors which to me looks like the server memory is full.
I am not concerned about loosing the configuration files because customer has few devices monitored and I can always rebuild it.
My only concern is, will I loose the DCE Licenses once I restore it a fresh from existing v7.4.3 to v8.1.0 considering there is operating system change on the two version, if yes what should I do not to loose the Licenses now that DCE can't be accessed on client and showing still starting up on Web.
Thank you.
Regards
Felix
Admiral
Posted: ‎2024-09-06 11:51 AM
1047
Hello @Angwenyi,
I would recommend connecting with technical support on this.  If the server is accessible via SSH they likely can resolve the issue (if it is a true storage issue).
However, if rebuilding is easy due to the number of devices that are discovered, I would recommend deploying the newest DCE version and then contacting technical support to have the licensing redone if there was a MAC address change to the server.  Redeploying and reconfiguring likely would be quicker than running through the incremental upgrades.
Kind Regards,
Cory
Admiral
Posted: ‎2024-09-25 06:26 AM
In response to Angwenyi
Hello @Angwenyi,
If it is the same physical DCE Appliance (AP9465/AP9470/AP9475), the same license keys will work as the MAC address will not change.  License keys can be retrieved from the Entitlements Portal.  If you do not have access to the portal, please contact technical support.
Kind Regards,
Cory
Admiral
1048
Hello @Angwenyi,
Kind Regards,
Cory
Angwenyi
Lieutenant JG
Posted: ‎2024-09-24 07:47 AM
In response to Cory_McDonald
969
Thank you Cory
Considering it's the same physical server do should I expect MAC address change?
Thank you.
Felix
Admiral
Hello @Angwenyi,
Kind Regards,
Cory
