Posted: 2020-07-04 03:12 PM . Last Modified: 2024-04-05 12:41 AM
I have configured a DCE (7.5.0) as an External System Configuration to DCO (8.2.2), but the Data in DCO device window doesn't match with the data on the device:
Enzo
(CID:129406138)
Hi Enzo,
DCO will take peak power over the period based in settings for "calculate power data based on days' per picture below.
By default, it will keep last 30 days data.
The rack PDU NMC showed peak power of 10.11 kw back in 09/16/2015, which is more than 30 days.
For more information:
About Peak and Average Power Data Retrieval from StruxureWare Data Center Expert
(CID:129406335)
Hi Christopherus,
I was referring at the total KW, as you can see from the pic on the device is 7.78KW and in DCO is o KW
Enzo
(CID:129407095)
Posted: 2020-07-04 03:13 PM . Last Modified: 2024-04-05 12:41 AM
Now that you mentioned, the average power is shown as zero, and the average individual phase power has no data in DCO.
Jef Faridi, any idea?
I've highlighted Enzo's original screenshots on the average power:
(CID:129407141)
I think I have found the solution, I applied the patch at:
and now I am getting the right value
Enzo
(CID:129409434)
Posted: 2020-07-04 03:13 PM . Last Modified: 2023-10-22 01:50 AM
