Posted: 2020-07-02 08:22 AM . Last Modified: 2024-04-10 01:31 AM
I have got below queries on Data Center Operation version 7.4.
Query #1: There are gaps in CSV file when for example Inventory Report is generated. There is no gap within DCO Report generation, but there is a gap between the rows if the inventory report is exported in CSV. Please find the Attached Screen shots for this difference.
Query #2: As of now there is no auto scheduling facility in DCO as we can do it in DCE by using manage export scheduling option. I would like to see Auto Scheduling similar to DCE Manage Export Scheduling option. Is there any plan for having this feature in DCO in the near future?
(CID:89555373)
Hi, we will look into your question and get back to you
(CID:89555384)
Ad #1 I have seen the same issue at my end and is investigating further. Are you using the standard report in DCO or did you create a special report design? Reason for asking is that it might be possible to upload a new report to the server once the issue is tracked down.
Edited: A new report design has been created: inventory.rpttemplate
The report design can be imported into the DCO server using the File->Import->Insight Report Design menu. The existing inventory report can be overwritten or a new version can be saved.
Ad #2 There is at present no plan regarding the scheduling subject other than we are very much aware of the lack of scheduling capabilities in DCO.
Going forward please track one question per post/question in the community. This makes future tracking/searching for fellow community users easier.
(CID:89555483)
Hi Soren, I was told that this is the standard report in DCO. For Example: Inventory Report
(CID:89555538)
The answer now includes a new report design for the inventory report. This is the same design and layout as the standard/default report shipped with DCO. The only difference is .csv and .xls file export of the report does not have an extra line in the rack mount PDU section of the report.
(CID:89555539)
Hi Soren, Could you please confirm if this issue will be resolved in the next revision? We are getting gaps in each rows when the report is exported it in .CSV file from DCO 7.4.
(CID:89555621)
Posted: 2020-07-02 08:22 AM . Last Modified: 2023-10-31 10:23 PM
