Data Center Expert 7.9.0 released
  • Data Center Expert 7.9.0 released
126
65
JLehr
Sisko JLehr Sisko
Sisko
Posted: ‎2022-02-23 04:39 AM
1
3063
The Data Center Expert 7.9.0 release updates the server operating system to Rocky Linux 8.4. The upgrade from DCE 7.8.1 requires a fresh install of the software or a new VM.
It is required that you contact support to verify you have a valid software support contract and to discuss your upgrade options before you receive the Data Center Expert 7.9.0 upgrade file.
You must have a valid software support contract to receive the Data Center Expert 7.9.0 upgrade. If you do not have a valid software support contract, then you will need to purchase one to receive the upgrade.
In this release:
  • SMBv2 and higher support
    Server Message Block (SMB) v2 and v3 are supported in Data Center Expert 7.9.0 and newer.
  • Server access option changes
    The SSL option in the Server Access > Web server tab was removed. Private proxy and web server SSL/TLS are now included in a security policy you select in the System > Server Administration Settings > Server Access option.
  • Additional SNMPv3 device discovery options
    SNMPv3 device discovery options now include additional authentication and encryption types.
  • UTF-8 support for self-signed certificates
DCE 7.9.0 release notes
  • Data Center Operation
  • IT Advisor
Sandro.Estaba
Lieutenant JG Sandro.Estaba
Lieutenant JG
Posted: ‎2023-03-30 01:32 AM
Thank you for sharing the release notes announcement
Sandro.Estaba
Lieutenant JG
