Posted: 2025-08-29 06:27 AM
We recently installed 3 Vertiv Racks with cooling units in them. They are on a Penthouse Mechanical floor. They came with a Liebert IntelliSlot RDU-SIC G2 card. The stock DDF on Data Center Expert 8.3.0 does not pull in any points or information. Is anyone else monitoring this card with DCE?
Posted: 2025-09-01 08:10 PM
You may go to https://ddf.ecostruxureit.com/ and check for the corresponding DDF via search.
BR,
TJ
Posted: 2025-09-03 05:45 AM
Thanks, it was there. I searched for that bookmark and couldn't find it. It should be something easier to find.
Posted: 2025-09-03 07:59 AM
I downloaded the DDF file and installed but it does not pull in the RDU-SIC G2 points.
Posted: 2025-09-04 08:15 PM
Have you checked the SNMP settings (access control, SNMP string, etc.) in the RDU-SIC? If yes, try to perform a device walk on DCE's webpage.
BR,
TJ
