DDF for IDAV 1021A (Uniflair LE Precision Air Conditioning)
  • DDF for IDAV 1021A (Uniflair LE Precision Air Conditioning)
127
65
Posted: ‎2020-07-05 12:15 AM . Last Modified: ‎2024-04-04 12:57 AM
1296
I need DDF for Uniflair LE Precision Air Conditioning model IDAV 1021A model. After searching in device support it says IDAV model supported as below:
Please advise which ddf file to download from the below listed to read sensor values from IDAV 1021A model:
Or if I have to request for a new DDF for IDAV 1021A model?
Thanks & Regards
Shemil
(CID:134037588)
  • DDF
Dear shemilusman,
On the Device Support resource, I found, by the key phrase "idav", only two web-links to download, as it seems to me, the correct DDF-files:
Depending on the connection protocol of your cooling device, you must use one of the two DDF-files. I think you should first try the SNMP DDF-file, and then perhaps a TCP/IP DDF-file.
With respect.
(CID:134037651)
Dear shemilusman,
Tell us, please, did you solve your question or not?
With respect.
(CID:134679935)
Posted: ‎2020-07-05 12:15 AM . Last Modified: ‎2023-10-22 01:48 AM
