DDF for DSE7420 genset controler
  • DDF for DSE7420 genset controler
126
65
Posted: ‎2020-07-05 03:24 PM . Last Modified: ‎2024-04-03 11:26 PM
1213
we have issus triying to connect a DSE7420 genset controler using DDF deepsea_generator_gencomm. We received communication error. it only Works using the DDF Lite versión.
Is posible to check why it is not working?
Thanks in advanced
(CID:137112449)
  • DDF
1213
Hi Sergio,
Would you mind going to the device support page at http://sxwhelpcenter.ecostruxureit.com/devices then search for DSE7420?  You can download a different DDF from there.  If that one doesn't, work, click on the "Request Modification" and type in the issue you are having.  This will create a ticket for my team to assist you.  We can troubleshoot from there.
Jake
(CID:137112473)
Replies 6
1214
Hi Sergio,
Jake
(CID:137112473)
Hi, Jake
we will proceed as you indicate.
(CID:137726056)
Jake, what documment we need to attach for DDF modification?
(CID:137726063)
Posted: ‎2020-07-05 03:25 PM . Last Modified: ‎2024-04-03 11:26 PM
If a DDF isn't working for you, please provide the DDF (if possible), and screenshots of the errors and the "view sensors" screen for the device.
(CID:137726106)
thanks, Jake...
(CID:137726118)
Posted: ‎2020-07-05 03:25 PM . Last Modified: ‎2023-10-22 01:48 AM
