DCO8.3.2 SSL Certificate
  • DCO8.3.2 SSL Certificate
128
aashraf
Lieutenant JG aashraf Lieutenant JG
Lieutenant JG
Posted: ‎2020-12-17 07:02 AM
1977
Dear Gents,
Based on this article
https://dcimsupport.ecostruxureit.com/hc/en-us/articles/360036928393-Changing-SSL-certificate-on-the...
The DCO SSL certificate needs to be an Apache 2.x/PEM format certificate consisting of two files (*.key, *.crt).
But the customer needs to extract a CSR to create a certificate for the DCO like we did in DCE,
Is this applicable in DCO or it should be Apache 2.x/PEM format certificate consisting of two files (*.key, *.crt) ?
And if this is applicable, how to extract this CSR from DCO? And how to upload the certificate without (*.key) file?
Ahmed Ashraf
  • Data Center Operation
Captain
Posted: ‎2020-12-17 07:31 AM
Hello Ahmed
I attached a pdf you can use as a reference to create a CSR from a DCO or ITA server (should work on either).
Regards
Greg Sterling
Captain
Posted: ‎2020-12-22 08:40 AM
In response to Anonymous user
Hello
Are you making a comment or asking a question as a follow-up to this post?
You are correct in regards to signed SSL certificates. They need to come from a trusted authority, usually a third party.
But the procedure attached to the below post or this help center page https://helpcenter.ecostruxureit.com/hc/en-us/articles/360016589697-How-to-manually-create-a-CSR-cer... should allow the user to fetch the current SSL key for their DCO/ITA server and create a certificate signing request.
When the CSR is signed either internally or by a trusted authority, then that signed certificate along with the original key created in the procedure should allow you to apply a signed certificate to your DCO/ITA server.
Regards
Greg Sterling
