Posted: 2020-07-04 03:27 PM . Last Modified: 2024-04-05 12:37 AM
Hi Team ,
We have DCO8.2 cluster on customer site and facing one issue about application service down on slave node,please see the screenshop as below , we have 218.32.211.168/169 node and virtual ip for 218.32.211.170, whatever we exchanged master on these two nodes many times, the application service always down on slave node, I also share the log files on box for your reference,kindly check what's problem on this ,thank you .
https://schneider-electric.box.com/s/4u663ig7lj5432xs4mwe5stewdwqosx6
(CID:129408379)
Hi!
We have the same issue and recommendation is migrate to Standalone + DR node configuration.
As I know, cluster feature will be decomissioned in future
(CID:129408391)
Posted: 2020-07-04 03:27 PM . Last Modified: 2024-04-05 12:36 AM
Hi Valentin ,
Thank you for kindly response , is this issue only happened on 8.2 version?
I installed it success and working fine on 8.1 .
I would like to know what's the problem on this case ?
Can someone advice base on the log files? Much appreciated.
Best Regards
(CID:129408923)
Posted: 2020-07-04 03:27 PM . Last Modified: 2023-10-22 01:47 AM
