DCO - setting CAD files as a room background
  • DCO - setting CAD files as a room background
126
65
Posted: ‎2020-07-03 03:34 PM . Last Modified: ‎2024-04-08 12:55 AM
773
Sometimes when I try to add a CAD file to set the room background, I find some problems. The most usual is "Drawind contains unsupported elements: 1) Wipeout"
I'd like to know the list of all unsupported elements in DCO and how can I ask to the customers the best way to generate a CAD files supported by DCO.
Best regards,
Enric
(CID:116925654)
  • Data Center Operation
Hi Enric Climent
New CAD applications keep extending DWG format, so it is easier to list the elements that are supported by the importer. You can find a full list here:
CAD Import Supported Entities
(CID:116925829)
Hi Enric Climent
(CID:116925829)
Posted: ‎2020-07-03 03:34 PM . Last Modified: ‎2023-10-22 01:45 AM
