DCO problem with red racks, PDU:s and UPS:s
  • EcoStruxure IT forum
  • DCO problem with red racks, PDU:s and UPS:s
126
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-05 12:21 AM . Last Modified: ‎2024-04-04 12:55 AM
522
Hey all!
So I have weird problems. Lets say that I have UPS and PDU and I have 11 rack with rack PDU:s connected to them without any equipment in those rack. I have 3 of those 11 racks red and complaining about power numbers even tho the sensors that collects data IRL gives ok values at DCO sensor mapping. UPS and PDU that feeds power to those racks are also red and showing crazy numbers. For example. This is image from UPS that feeds PDU that feeds those 11 racks with Rack-PDU:s
Also PDU and some racks ( not all 11 ) and Rack-PDU:s are effected by this. Anyone know what this means?
Best Regards,
Jani
(CID:134678797)
  • Data Center Operation
Hi Jani,
Those information are basically on your setup (eg. how exactly the power path is configured), Apparently you have too much power consumer connected to UPS and/or perhaps you might have some 'misconfiguration' somewhere.
Following page describe the info displayed in the power tool tip: What does the power tool tip tell me
Can you add more details, such as how you get the measurements in DCO (from DCE?), screen captures illustrating the measured peak on racks (rpdus) and PDU...
If you can provide a copy of your setup (backup), then I can take a look and see what might be the issue. I will send you an invite to my =S= box shortly, so the data safely can be shared with me (if you would), thanks.
Kind regards
(CID:134678889)
Posted: ‎2020-07-05 12:21 AM . Last Modified: ‎2023-10-22 01:45 AM
