Posted: 2020-07-04 06:00 PM . Last Modified: 2024-04-04 11:43 PM
Hi Im running DCO 8.2.2 with capacity licence, I have two DC's at different locations and I have ac units and ups's associated to the relevant physical device but I'm finding issues. In the web portal only one location is showing power and 'u'space location 1 is correct however location 2 also has 10 + racks and 2 x 180 kW UPS.
In the DCO client no measured values are displayed at all power or cooling
TIA
Mike
(CID:131963918)
Was location 2 created recently?
Capacity calculation is done daily at specific time, you can check this under Client preference.
If yes, by the time you read this, you should see the capacity info updated ...
(CID:131964108)
Posted: 2020-07-04 06:00 PM . Last Modified: 2023-10-22 01:45 AM
