DCO export layout image resolution
  • DCO export layout image resolution
129
72
Posted: ‎2020-07-02 07:10 AM . Last Modified: ‎2024-04-10 01:45 AM
758
Is there a way to increase the resolution of exported layout images in DCO 7.3.6?
I would like to print on large format paper.
(CID:85885183)
  • Data Center Operation
Posted: ‎2020-07-02 07:11 AM . Last Modified: ‎2024-04-10 01:45 AM
Select .svg as the export format and open the file in a browser.
(CID:85885204)
Pete,
In version 7.36, your only option is SVG format. There is software available which allows you to print the SVG format in larger versions.  In version 7.4 (available now I believe as long as you are under support), there is a DWG (CAD) export format available which would also allow you to print in larger formats.  Hope this helps
(CID:85885203)
(CID:85885204)
Posted: ‎2020-07-02 07:11 AM . Last Modified: ‎2023-10-31 10:49 PM
